TwinTurbo.NET: Nissan 300ZX forum - Re: I'd double check the timing belt
Lets_Go_Blues
on August 07, 2012 at 9:07 PM
I'd double check the timing belt (n/m)
posted by aliaZ
on August 07, 2012 at 07:12 PM
The driver side timing cover will be easy.. its that damn passenger side. Does this sound like a potential jump? is was dead on when we set it and had 5mm gap in the tensioner.
Issues after jdm swap
Lets_Go_Blues
15:59:12 08/07/12
Re: Issues after jdm swap
Lets_Go_Blues
16:01:37 08/07/12
Re: Re: Issues after jdm swap
Lets_Go_Blues
16:13:33 08/07/12
aliaZ
19:12:30 08/07/12
Re: I'd double check the timing belt -
Lets_Go_Blues
21:07:52 08/07/12
Yes,CAS issue is what happens when the belt is off a bit
jzack
21:34:04 08/07/12
Re: Yes,CAS issue is what happens when the belt is off a bit
Lets_Go_Blues
22:19:31 08/07/12
Well if you can get the timing right w/out maxing the
jzack
20:12:19 08/08/12
How are you testing the boost leak? (n/m)
dvice
00:16:15 08/08/12
Re: How are you testing the boost leak?
Lets_Go_Blues
02:07:14 08/08/12
To my knowledge, it SHOULDN'T build pressure.
PiotrC70
23:14:48 08/08/12
Couple things....
300ZMang
11:33:39 08/08/12
Compression should be higher when warm, no? (n/m)
Summeronthechain (MN)
11:48:43 08/08/12
Well he said cylinders showed 150+ psi when cold
300ZMang
11:32:53 08/09/12
Re: Couple things....
Lets_Go_Blues
12:46:06 08/08/12
Well if you don't need advice... and you know so many
300ZMang
11:33:48 08/09/12
Well, you have to find the boost leak first.
11:48:12 08/08/12
Re: Well, you have to find the boost leak first.
Lets_Go_Blues
13:19:04 08/08/12
Maybe check the upper/lower intake manifold. Could be a
JonnyZ(SoCal)
16:07:13 08/08/12
